I'm playing around with hub mesh. If I update a device on the source hub, the status change is reflected on the destination. However no commands run on the destination do anything. The commands work fine on the source hub. Nothing in the logs on either hub, anyone have any thoughts?
Have you tried restarting both hubs? And using TCP instead of UDP?
I tried rebooting but haven’t tried TCP yet. There isn’t anything weird networking wise though between them, just two ports on the same switch.
I have the exact same setup. The switch is an unmanaged switch.
Yeah mine is unmanaged as well.
Sigh TCP was worse, all the devices say they're offline. As soon as I switch back to UDP they're at least online again.
Time to tag @gopher.ny
