Sorry if this has already been covered but I'm not finding it.
Add Hub Mesh linked remote devices to Past Log history. With live logging I can see linked remote devices change state but those log entries are not making it into the Past Logs.
I don't know why you aren't seeing them, past log entries are appearing in my Past Logs pages:
app:562020-12-16 03:58:26.699 pm infoGarage Door Opener on Hub-1 closed @ 03:58 PM 16-Dec-2020
app:562020-12-16 03:58:26.682 pm infoGarage Tilt Sensor on Hub-1 closed @ 03:58 PM 16-Dec-2020
app:562020-12-16 03:58:23.944 pm infoKitchen Door Sensor on Hub-1 closed @ 03:58 PM 16-Dec-2020
app:562020-12-16 03:58:18.318 pm infoKitchen Door Sensor on Hub-1 open @ 03:58 PM 16-Dec-2020
dev:2342020-12-16 03:57:32.525 pm infoOutdoor Light Switches switch is off
app:562020-12-16 03:56:53.717 pm infoGarage Door Opener on Hub-1 open @ 03:56 PM 16-Dec-2020
app:562020-12-16 03:56:53.668 pm infoGarage Tilt Sensor on Hub-1 open @ 03:56 PM 16-Dec-2020
The log is from my applications hub "hub 2", "hub 1" is my C4 that runs radios.
S.
I'm only seeing this one dev: entry and seeing that it doesn't show as "on Hub-1" I'm guessing it is on Hub-2.
@gd_brock, You know. You're 100% right. I didn't read it that way initially, but that's because I blatantly missed the "app" prefix and just saw the Sensor. D'oh.
I have most of my logging turned off. Let me see if I can get something to show up.
Well. I'll be. Just switched some motion sensors to "chatty mode", and I see the activity in the rolling log, but not in the Past Logs. Interesting. @bravenel is this expected behavior?
S.
Here is what I'm seeing in the live log for flipping a linked switch.
Here is the Past Log.
The app event local to this hub makes it into the past logs but not the dev entries. The other hub with these devices is logging these devices but the apps are not there so matching up devices with app events is more difficult when split like this.
That's weird. There's nothing intentionally special about those devices' logs' handling. I'll take a look.
Thank you.
