When I look at my hub mesh the IP address of my C5 is wrong....... If I click on C5-1 it will try to take me to the bad IP address and will fail. How can I get this to show the correct address? My Asus router has the correct IP address manually set - top image. I'm guessing the mix up is in my Hubitat devices.
Your C-5 has a self-assigned IP address. This happened because your C-5 booted before your router did (presumably after a power loss situation or a reboot of your router and hubs).
