Hi all,
I've successfully gotten two Hubitat hubs to see each other across two different subnets with routing confirmed between them. Sharing the setup details in case it helps others, but I'm stuck on one remaining issue and would appreciate any insight.
Setup
- Hub L: C-8, 192.168.86.50, platform 2.4.4.151
- Hub N: C-7, 192.168.87.51, platform 2.4.4.151
- Routing between subnets is fully confirmed — both hubs can ping and traceroute to each other
- mDNS is working across the subnets
What works
- Hub Mesh discovery — both hubs show as Active
- State sync from N → L — when a device changes state on Hub N, the linked device on Hub L updates in real time
- TCP connectivity on port 8083 between both hubs confirmed working bidirectionally via tcpdump
What doesn't work
Commands issued from Hub L to linked Hub N devices do nothing. Hub L's UI shows "Command Submitted" but nothing executes on Hub N, and nothing appears in the logs on either hub.
Troubleshooting done
- Confirmed port 8083 open and bidirectional via tcpdump — both hub UIDs and IPs visible in payloads, connection healthy
- Confirmed both hubs can ping and traceroute to each other
- Ran
http://<hubIP>/hub/allowSubnets?<subnet>on both hubs specifying both subnets, as suggested in this thread where it resolved a similar issue for another user — no change in behavior - Removed and re-added linked devices on Hub L
- Rebooted both hubs
Key observation from tcpdump
Traffic between the hubs on port 8083 is active and healthy — I can see both hub UIDs and IPs exchanged in the payloads. When I issue a command from Hub L the UI returns "Command Submitted", and I do see continued traffic on port 8083, but nothing appears in the logs on either hub and the device doesn't respond. There are no error messages anywhere.
The asymmetry is the puzzling part: state changes flow N → L reliably, but commands L → N are silently ignored despite an established TCP connection and "Command Submitted" in the UI.
My working theory is that Hub N is receiving the command packet but rejecting it silently — possibly due to subnet validation logic that doesn't recognize Hub L's subnet as trusted even with allowSubnets applied. But I'm speculating.
Has anyone successfully gotten bidirectional Hub Mesh command control working across two subnets? Is there something else in the hub's network trust model I'm missing?
Most importantly: is there any logging available? I don't see ANY activity in either hubitats logs.
