Hub Load is Severe error (Resolved)
Hi,
I am getting a Hub load is severe error, I found that my new phone and the Maker API app are not happy.
I updated the phone name, ip address, etc etc and updated all the apps where it was referenced.
I did some reading but it took me nowhere.
can anyone point me in the right direction on how to troubleshoot this?
Thanks,
Sam
Are you on the latest platform?
What version of firmware are you on? 2.3.4.1xx ? Is there an update available to 2.3.4.139 for you maybe?
Bug Fixes
  • Fixed high CPU usage/memory leak under certain conditions.
Thanks,
I am on 2.3.4.148.
I just noticed that the iphone wifi presence detector is not showing up.
It looks like you may be using something a bit more then the standard presence with the Hubitat app. Have you tried restarting your phone.
Is that a correct impression? If so what is the method you are using for managing presence between the phone and Hubiat.
Yes, I just rebooted the phone and the hub, will let you know. THANKS!
The hub reboot seems to have done it. strange because I rebooted it a few times while upgrading and soft reset.
thanks for your help,
Sam
