Hub LED green even when disconnected - BUG?
Something has changed.... I'm pretty sure before when the hub was disconnected it turned red...
now regardless of connection status it stays GREEN
I waited 5 minutes no change ....
Is there a bug with the current firmware?
Thanks!
You may want to confirm the exact firmware you are using. And when you say disconnected, what exactly are you referring to? Is there a status of disconnected you are seeing on a screen somewhere? Perhaps include a screenshot?
I am at the latest firmware although I think this behavior has been like this for a while and disconnected means I unplugged the ethernet cord : ) From my PC, I have confirmed I cannot reach the hub (would be difficult w ethernet unplugged) : )
Ok, the only reason I suggest including the actual version number is that "current" does not always remain current for long. It's probably not going to make a difference in this case, but in other situations, particularly if a topic drags on....
Green just says that the Hub UI has loaded successfully and is ready to respond. If the hub is disconnected, the UI is, of course getting nothing to respond to; all other communications (Zigbee/Zwave) will be merrily going about their business uninterrupted.
Nothing has changed. LED colors have meant the following for C-5 hubs since their release in 2019, and C-7 hubs since their release in 2020.
  1. LED Blue: Power connected, Linux OS loaded (hub platform is not running, diagnostic tool may be accessible)
  2. LED Green: Power connected, hub platform loaded (platform & diagnostic tool are running)
  3. LED Red: Power connected, OS and platform not running
Thanks for the great clarification
