I switched to the low bandwidth mode. Still having the problem with it locking up. It locked up 3 times today.
Ouch! Tagging @Eric_Inovelli, @ericm - any possibility of a firmware update that makes these bulbs less chatty?
i don't have any innoveli lights but my hub's been locking up frequently after the 2.2.1.113 update and even more frequently after 2.2.1.115.
I've e-mailed hubitat support but if anyone has any suggestions or gets further on OP's issue it may be helpful
What do your logs show? Also - probably best to start a new thread because @natebradley's issue is apparently linked to iNovelli bulbs.
There's nothing in that update that would cause a lockup.
Easy to verify. Use the Hubitat Diagnostic Tool and roll back to 2.2.1.113
I must admit whenever I see reference to the 'Hubitat Diagnostic Tool' I think of something that we can turn on/invoke to give us more information (diagnostics) to see what is going on and may be causing issues with the hub.
I see this more as 'Things to try to get your hub working' tool.
Just my opinion.
This will assist in his hypothesis that the hot fix caused the hub to lock up. So in this case, I’d call it a tool to help diagnose the problem, wouldn’t you?
Spoken like a true staff member. They got the right guy for the job.
I don’t name the tools, I just know what they’re for.
Yep. And that's even what it says it is. If there's misnaming going on, it's not SmartHomePrimer that put those words on the Page, I bet.
Oh heck, and I'm still trying to figure out the meaning of Diet. Is there documentation?
Yea, me too. Trying to reduce the number of hubs, maybe? Won't find success around my place.
Should I worry? I ran the hotfix on both of my hubs last night. Seems to be running ok today.
Ok, I’m off my diet
Now you're... nothing
An earlier suggestion. Better?
This is better, I think.
Makes me sound more exciting than I actually am.
I’ll try this on for a while
You ARE exciting. If I can choose then I choose Diet. Gave me a chuckle.
Out of context, it made no sense. Thanks for the compliment.
