Hub Information Driver fails to updated via HPM
@thebearmay
Hub is still running 2.3.1.142
(Don't fix whatever is not broken my internal policy).
Whenever I am doing/trying driver update via HPM I am always
having trouble with Hubitat Information Driver (btw, everything
else updates without any problems).
Sometime after few failures it finally updates successfully.
This time it fails consistently after many attempts.
So, I am reporting a problem.
Here is (unfortunately not to informative) a related log:
Normally, for me, this is due to Github not responding timely.
I have many things installed via HPM and have a problem
only with Hub Information Driver. The rest is flying.
Question is - why this is happening to only Hub Information Driver?
I guess, this is something to think about.
It has gotten a little larger than most (1300+ lines) so it does take a little longer to copy over, and the more time the more opportunity to time out. For what it’s worth I find that the Repair option works better most times.
Well, just tried a Repair option few times.
Log reports exactly the same error.
Where is this timeout in question?
Is this HPM problem?
Just tried an update and had no problem.
Tried again in a middle of the night and this time it did work.
