Hub Froze
C8-Pro
2.4.3.137 (on previous version also)
ZwaveJS
My hub all of sudden stopped responding to zwave commands and also stopped running my apps (Amazon and Google couldn't send commands).
I did a shutdown and power pull, booted back up and still was in an unresponsive state. I saw the current firmware available so updated. When the system booted back up, it continued to be unresponsive.
I switched by ZwaveJS to Zwave Legacy, hub rebooted and everything is back to normal.
I've got these Zwave logs:
2025-10-14 07:43:06.632 PM|DRIVER « [RES] [SendDataBridge] - was sent: true
2025-10-14 07:43:06.632 PM|SERIAL » [ACK] (0x06)
2025-10-14 07:43:06.630 PM|SERIAL « 0x010401a90152 (6 bytes)
2025-10-14 07:43:06.625 PM|SERIAL « [ACK] (0x06)
2025-10-14 07:43:06.622 PM|DRIVER » [Node 111] [REQ] [SendDataBridge] - │ source node id: 1 - │ transmit options: 0x25 - │ callback id: 59 - └─[NoOperationCC]
2025-10-14 07:43:06.618 PM|SERIAL » 0x010f00a90001006f010025000000003b28 (17 bytes)
2025-10-14 07:43:06.614 PM|CNTRLR Switching to 16-bit node IDs successful
2025-10-14 07:43:06.608 PM|DRIVER « [RES] [SerialAPISetup] - command: SetNodeIDType - success: true
2025-10-14 07:43:06.605 PM|SERIAL » [ACK] (0x06)
2025-10-14 07:43:06.604 PM|SERIAL « 0x0105010b800171 (7 bytes)
2025-10-14 07:43:06.602 PM|SERIAL « [ACK] (0x06)
2025-10-14 07:43:06.600 PM|SERIAL « [ACK] (0x06)
2025-10-14 07:43:06.598 PM|DRIVER » [REQ] [SerialAPISetup] - command: SetNodeIDType - node ID type: 16 bit
2025-10-14 07:43:06.594 PM|SERIAL » 0x0105000b800273 (7 bytes)
2025-10-14 07:43:06.589 PM|CNTRLR Switching serial API to 16-bit node IDs...
2025-10-14 07:43:06.587 PM|DRIVER » [REQ] [StartWatchdog]
2025-10-14 07:43:06.585 PM|SERIAL » 0x010300d22e (5 bytes)
2025-10-14 07:43:06.574 PM|DRIVER « [REQ] [SerialAPIStarted] - wake up reason: WatchdogReset - watchdog enabled: false - generic device class: 0x02 - specific device class: 0x07 - always listening: false - supports Long Range: true
2025-10-14 07:43:06.575 PM|CNTRLR Serial API restarted unexpectedly.
2025-10-14 07:43:06.572 PM|SERIAL » [ACK] (0x06)
2025-10-14 07:43:06.569 PM|SERIAL « 0x0114000a03000302070a5e5556226c748a8f989f018a (22 bytes)
2025-10-14 07:43:05.254 PM|DRIVER « [RES] [SendDataBridge] - was sent: true
2025-10-14 07:43:05.251 PM|SERIAL « 0x010401a90152
