I migrated my C8 to a C8 Pro yesterday, all went smoothly but my Cloud Backup did not any local files in it. I don't need help, I'm just curious why my files didn't migrate.
I had Hub Protect on the C8, so I didn't have any option to create a migration cloud backup, just the standard cloud backup. I created a new cloud backup manually before the migration.
I'm pretty sure my files have moved in the past when migrating... so I'm curious why my cloud backups do not have files in them now.
It wasn't all bad... I had tons of old svg files I needed to clean out that I don't use anymore, so I just booted up the old C8, downloaded only the files I needed, and uploaded them back to the pro.
Regardless, I must say that otherwise it was a very smooth migration. Even with the C8 backup on an older platform, and the C8 Pro on a newer but not current platform, everything updated correctly. Then I brought the pro up to the latest version after migration was complete. I'm sure it is best practice to have the hubs at the same level, but it worked fine for me with them at different levels and the update was applied during migration boot. My issue was the C8 was so maxed out that upgrading platform first on the C8 would have taken like an hour, so I was able to bypass needing to upgrade the C8 before migration, so the whole migration took less than an hour.
Ok, I'm not going crazy then. Looking at the size of the cloud backups that have been taken recently, as well as the manual one, all of them are too small to contain my files (backups are 10MB in size, and my files on that hub were about 250MB.
That is why I am wondering if I reached a cloud usage size limit or something, so it stopped backing up files? I'm not sure when it stopped adding local files to my cloud backups.
@bobbyD, is this result from AI correct? Seems like it could be a hallucination, but it matches what I am seeing....
AI says there is a strict 100MB size limit for file manager files in cloud backups, and local files get dropped entirely from cloud backups when that is exceeded.
That would have been nice to know before migration, where I assumed I still had local files being backed up in cloud backups. In which case, I guess the solution would have been to do a soft reset after migration and restore a local backup to get files back.
I don't believe that the files moved when I migrated from C-5 to C-7 and C-7 to C-8 a while back. I seem to recall that Jean May (@thebearmay ) developed some sort of utility to bulk download and upload the hub's files for backup and migration, and I used that to do the migrations.
I would have used that tool yesterday had I known it existed, but since I wanted to clean house on my files that would have been overkill.
I know when I went from C7-C8 I got my files. I also migrated a C8 to a C8, and it moved my files. This is the first time I have just used a standard cloud backup to migrate, as the hub already had Hub Protect, so I didn't have the migration backup option on the hub. My files were below 100MB at the time of those past migrations, however.
It has been said these are identical (cloud backup vs migration backup), but now I wonder... Does the free migration cloud backup also trim local files at 100MB?
Once I move my subscription over to the Pro, I should get the migrate backup button back on the C8. I am going to see if free migration backup includes files, and if it really is different than a standard cloud backup.
I asked before, and was told it didn't. Perhaps that has changed. That's why I used the utility by @thebearmay, which worked perfectly.
I believe that has been previously asked, and the answer was that they are the same except that the migration can't go back to the backup source, only a higher generation hub.
It most definitely has for me, twice. So it does, but my feeling is I passed a size limit like AI said, but we need to hear from Hubitat about that one.
So you are probably right, and neither method backs up files if you have over 100MB? That just doesn't seem right, though, there is nothing in the migration documentation that says you will lose files if they are over 100MB, I mean, it says nothing about losing files at all, and I don't think people would expect to lose files in a migration.
Ah, Ok, good to know. As I said, it was a good opportunity to clean out files, so no biggie for me. I'm just glad the rest of the migration went smooth.
