I get periods of time, up to minutes, where the hub just doesn't respond. Log attached: I push button 1 on the wallmote to open the garage door, twice, no response. I go inside to check logs and two min later as I'm at the computer the door opens. I feel like a nuisance to the community because I basically keep asking the same question in a different way, but this is unbearable. What would you do?
Assuming we're talking about an Aoetec WallMote, maybe it's as simple as a drained battery, found one of my Motes reporting a batterylevel of 255% before it dropped down to 0% and finally stopped working.
Hi,
It's not the battery, the log shows the button push was received when the button was pushed, both times.
The log isn't giving me any clues, I wish I could see what the hub was doing for two minutes while it was waiting to send out the command to open the door.
Something odd with the relay. That shows garage door is opening, then 1 second later the relay turns on. Also something further up shows a delay of 2000 that cannot be executed.
Looks like thereโs some other devices or malformed rules causing delays. Also, what other Zooz devices do you have on the hub?
I'm using "zooz garage door opener app" so I'm assuming the additional chatter about relays opening is just the app reporting that it's going to open the door, and then the device actually opening.
90% of the time, this whole setup works as intended. The other 10% of the time the hub just freezes.
I have no other Zooz products in my hubs. I am using mainly inovelli devices.
The delay 2000 has to do with an Aquaris zigbee single button device, battery powered, that I keep on my desk to turn a lamp on/off. That is interesting but it's reporting after the garage opens so not sure if it's related, possibly? I can unpair the button for a while and report back in a few days.
Thanks for taking the time to help!
