This morning I found two updates for my hub were ready to install.
I downloaded a backup, and proceded with the update.
After about five minutes the update page sayed that the hub was going to restart.
Never came back online
I checked to see if I could connect to the diagnostics update, but it to was dead.
Checked the physical hub, and there was a blue light, intermitted: ten seconds bue, two seconds off (rinds and repeat)
Took the power off for 30 minutes, but after re-powering the hub the same issue.
I my hub dead again?
(did create a ticket with Hubitat)
Press the reset button on the bottom of the hub with a paperclip to clear the network settings and see how that fares. Your database could also be corrupt.
But would a corrupt database also disable a simple ping to the device?
The MAC adress of the hup is not found on my network (and yeah, I did check the cable)
It could stall on bootup but unlikely. I would try the reset button, and if it comes back even 3 hours later, do a soft reset and restore from the database you downloaded to your pc. Also what color is the led?
This is what bothers me. Almost sounds like a bootloader error, but depending on what happens at the 10 second mark it could very well be a database corruption issue.
Please send me a PM along with your hub's MAC or hub id. I would also take the hub out of UPS for the moment to eliminate the possibility of power failure caused by UPS. In rare cases it could be a software issue with how the hub is starting up, but more often than not, blinking blue light is 99.9% related to power failure.
