My internet went down for a week which some how resulted in the c7 hub crashing needing to be restored. Managed to restore from a backup however now google or Alexa won’t re link back up at all.
I’ve removed the apps in hubitat, then google or Alexa and re synced them but it still fails with the state error. Any ideas? Thanks!
It is hard to determine what the problem is without additional information, but reading between the lines, failing with the "state error" often means that you are trying to authorize a device that is incompatible, or is missing the required state. I would make sure that all devices you are trying to authorize work as expected from Device Details page.
If you continue to have problems check this document to learn more about the kind of details you might want to provide so that others can help you get your hub fully functional again:
@bobbyD ive had a further look and the hubitat app on iPhone won’t connect to the hub either. When I select hub info it states a different ip from the one that has been assigned statically. The one I’ve assigned statically will work via the browser no problem which makes me think this is also linked to the Alexa/google issue. Any ideas?
This is so odd, which I knew what crashed the hub In the first place. Changed the static ip dns to cloud flare rebooted and tried your idea. Hub showed up on the correct ip address, tried adding Alexa and got further…..then failed. Tried a second time and it worked! However did the same with google and it won’t work at all…..will try again over the next few days
Do a DHCP reservation instead. It's more reliable. (Sometimes you think the DNS is set and it doesn't take when you do static, also you have a central place to look at all the reservations)
