Hub c8 Pro losing connection
Since about 2 weeks and last two updates my Hub is acting wierd. About 10 times a day I cannot access if remotely (over the Internet) via HD+ dashboard. Moreover, I noticed that in the same period I cannot access Webcore admin page locally. Therefore I assume it is some kind of Internet access problem on a hub. Any ideas, please?
Is the hub using ethernet or wifi to connect to the network? If ethernet, try removing wifi network and password if you happen to have that stored. My thought with that is just ruling out one complication that I previously came across, where I realized I didn’t understand the communication path I was on.
It is on LAN cable, wifi is not connected. Internet connection is stable and permanent on home network.
Do you have a reservation set for the hub? Do that first. Then using a toothpic or similar and press the network reset button on the bottom of the hub for 10 seconds (it's the only round hole out of all the square holes). Once that is done do a reboot with a database rebuild. See how it behaves after that. (Also make sure Jumbo frames are not enabled anywhere on the network)
Could it be the number of cloud calls?
What firmware are you in? Can you check the new cloud API calls tab in the logging page?
Do you have cloud extend or another subscription to enable above the free teir for cloud API calls.
Firmware 2.5.2.139, I cheched Cloud log and it seems it was a problem in number of API Maker calls that exceeded 3600 per hour.
