Hub became unresponsive / had to reboot [Custom Code]
So I have had hubitat for a few days and got it setup. this morning it became unresponsive. I was unable to connect to it. SO I rebooted it.
I then looked at the log file and noticed errors. (Same one over and over)
[error] java.lang.NullPointerException: Cannot execute null+0.4 on line 545 (parse)
Anyone else get this
If you click on the [error] part it will take you to the device or app that caused the error. It would be helpful to know which one it was.
Did not know that could be done. Found the devices with the issue. Looks like I need to speak to the person that created the driver for the devices. Thanks.
Would you mind actually sharing what devices / drivers it was? Could help someone else out...
I am using the "MagicHome Wifi - Controller (RGB + WW/CW CCT) 0.84" Driver that is causing me issues with all devices using it.
Albert and I coincidentally messaged each other at the same time this morning. Fix is in the works for all of the MagicHome drivers. Staff has been incredibly helpful.
