I wish to use HTTP to set/change the value of a string global variable in my hubitat. For testing purposes I was trying to do it from the browser on my computer. I am reading and using MakerAPI instructions. I created a Global Variable in RM. I tested with http://192.168.3.120/apps/api/909/devices/922/events?access_token=3b194cb2-d309-45c8-8dc9-166308b64ecb and that responded with the recent events OK. So I am confused should I be using a Send Device Command or a Send POST URL to set the value of my Global Variable? My assumption was the Send Device Command but I am having trouble figuring what to send as command and values. For testing I wanted to change the value of my Global Variabe to abc123. I tested sending http://192.168.3.120/apps/api/909/devices/922/CurrentValue/abc123?access_token=3b194cb2-d307-45c8-8dc9-166308b64ecb but I get An unexpected error occurred.
You really shouldn't post your access token on a public forum...
The POST url is the address the hub sends events to - it is not used to send commands to the hub.
In general you can only use Maker API to trigger COMMANDS. You can't just write to a random currentValue.
That said, I don't use variables in Hubitat, so maybe there is something special there that is different than normal devices.
Yup. I think @Angus_M makes use of a global variable connector device to keep the value of a NR global context in sync with a Hubitat global variable. At least at one point of time he was interested in doing so.
Good point. If you make a GV connector, you should be able to add that to maker api and write to it remotely. Something like this:
http://(hubip)/apps/api/(app number)/devices/(device number)/setVariable/(value)?access_token=xxxxx
EDIT: Just tried it, works fine.
Thanks much. Got it working OK. FYI the setVariable command does not work if the S is capitalized and that is what I was doing. Do you know is there a command list somewhere that shows exactly how each available command should be 'spelled.
Of course not. Commands are case sensitive.
Each command should show how it is spelled in the command box on the device detail page. So you should never have to guess. See below.
Or from Maker API you can get the details of a device, and it will list all commands (and obviously you can get the spelling form there too).
