HSM200 setting for Fahrenheit?
I have three HSM200 units in service - one reports in Fahrenheit and the other two in Celsius. The docs I've say there should be a setting in the device setup - I don't see one. The hub preference is set to Fahrenheit and I'm using the latest (6/25) custom driver for the HSM200. Any thoughts? How do I get all sensors to report Fahrenheit - or at least in the same unit!
A link to the actual code you're using (developers often start a topic here, so that is a good place to link to, but at the very least the source code itself) would be quite helpful, or posting there instead if you can find such a topic. It's likely there are multiple of these, making this even more important to know.
This is something the driver is doing for sure, as the hub can only convey the preferred units.
