HSM water leak detected - lots of Zigbee devices offline after until,HSM cleared
The leak sensor under the shower detected a valid leak and HSM closed the valve. :+1:
I pressed the Zigbee button in the living room to turn the lights on. Nothing happened. I went into the kitchen which would trigger the Zigbee motion sensor and turn on the basement lights. Nothing happened. Reset HSM, Everything responded.
I checked the rule several times, and the only actions are to close the valve and speak on a Google display. The section for ‘lights and switch alerts’ has nothing set.
This is all Zigbee if that matters.
The log for the remote shows it was pushed only after the HSM was cleared.
Any ideas ?
