I have everything working to arm in away mode whenever all members of my family leave the house. The issue I'm having is when I have someone stop over to check the house when I'm away. Their code unlocks the door and disarms the system. How can I have it say something like this?
Everyone away and system disarmed, re-arm after 30 minutes?
Do you have a smart lock that you use?
This is what I do when my "Domestic assistant" comes to clean my house.
lock code XXXX is entered set mode to home - which disarms hsm.
When she leaves, she uses her code again and it sets mode back to away and arms hsm.
You could also give them a presence detector like the smartthings arrival sensor. They work fairly well.
Just a thought.
I have a smart lock but it auto-locks after 60 seconds, which I have configured. So she puts the code in several times when at the house. I'll try what Carl listed above and see how that works.
I also have a tablet at the entry way running sharptools which we use when we come and go to arm the house. I just didn't want to worry about her remembering to do it or not. (She isn't very techy and would just be confused)
So I've created the conditional trigger with the IF/THEN for the presence and also added another condition that all the motion sensors are inactive. I'll see how this plays out. Thanks again, I didn't know about the IF/THEN conditional statements.
