Hi,
My HE has been running smoothly for half a year. I have a rule that sets mode to day and disarms HSM every 6am. However, the past couple of days after disarming at 6am it suddeny goes to away mode causing false alarms. It happens twice a day at random times. I just upgraded to 2.0.8.109 last night hoping it would take care of the issue but had the same issue this morning. I noticed an error for HSM today. See logs below:
2019-04-02 06:10:20.633 am errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.div() is applicable for argument types: (java.lang.Integer) values: [100]
Possible solutions: drop(int), is(java.lang.Object), wait(), trim(), find(), size() (setLevel)
app:392019-04-02 06:10:20.554 am errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.div() is applicable for argument types: (java.lang.Integer) values: [100]
app:2932019-04-02 06:10:20.503 am infoTurn Off Siren: Wired Siren switch on
app:392019-04-02 06:10:20.412 am errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.div() is applicable for argument types: (java.lang.Integer) values: [100]
dev:412019-04-02 06:10:20.372 am debugWired Siren is on
2019-04-02 06:10:19.734 am warnunable to turn on because device it's muted
2019-04-02 06:10:19.569 am warnAlert Intrusion Top Floor Motion Sensor active
2019-04-02 06:09:49.479 am warnAlert Intrusion pending Top Floor Motion Sensor active
app:372019-04-02 06:00:30.451 am infoArmed Away
app:372019-04-02 06:00:00.478 am errorgroovy.lang.MissingMethodException: No signature of method: hubitatSafetyMonitor.disarmModeHandler() is applicable for argument types: (com.hubitat.hub.domain.Event) values: [com.hubitat.hub.domain.Event@4adb4721] (disarmModeHandler)
app:372019-04-02 06:00:00.405 am infoArmed Night
app:372019-04-02 06:00:00.393 am infoArmed Home
app:2932019-04-02 06:00:00.299 am infoTurn Off Siren: CasaElarmo mode Day
app:1932019-04-02 06:00:00.118 am infoMode set to Day
