After latest update(124), HSM is not synchronizing with my Xfinity keypad, if I set HSM to arm home in Sharptools it will not change the status on the keypad and then you can't disarm HSM on the keypad. If I arm home or disarm directly on the keypad works fine.
I just put back 124, I noticed Sharptools is not activating arm home, arm away is fine, but this is the odd thing, to activate arm home inside HSM app I must click arm home button twice. If I click it once it will do nothing, I know I clicked the button once because the page refreshed but nothing was done until I click it a second time and the page refreshes again with the change.
Mike, I found something. I believe is something with the delay armed home by this many seconds setting, I had nothing but adding 10 seconds now works fine in any browser and in Sharptools, no double click needed in the browser.
There is an additional bug in the HSM sequence... I can reproduce it upon demand.
Hub Platform: 2.0.7.124
Keypad: Iris V2
Using the updated driver
HSM Settings:
Assuming a DISARMED state...
Device Keypad shows state of * entryDelay : 0
Click the PARTIAL button (Arm Home)
Device Keypad shows Current State Variable of LAST USED value (for the time consider this an unknown)
Countdown/beeps commences, correct HSM state & Keypad button displayed
Disarm
Click the ON button (Arm Away)
Device Keypad shows Current State Variable of * entryDelay : 15 [Notice: This is Armed Home value!!]
Disarm
Device Keypad shows Current State Variable of * entryDelay : 30 [Notice: This is Armed Away value!!]
Disarm
In essence what is happening is that whichever button on the keypad is pressed for an arming event after a disarm, the DELAY of the PREVIOUS arming event is used. Of course, should the same arming event be executed twice in succession, the 2nd arming event will use the correct delay value. If you use the same delay for both arming events you will never notice it.
Hope this makes sense, and as mentioned, it is reproducible upon demand.
Update 1 : When arming, both Away & Home from the Hubitat web interface, the correct delays are used all the time. Interestingly though, when doing an Arm Away, there is a line in red displayed showing the delay value. There is NO such display when doing the Arm Home.
Update 2: The Sharptools web interface is also behaving properly re delays when using it to arm.
This is a known issue with the release of the additional arm delay settings, this will not be fixed until the release of 2.0.8.
For now if you intend to arm from keypads,( and what's the point of having them if you dont), then all three delay settings need to be the same value.
