Trying to add the "Flash" capability to a driver for use with HSM, need some more info.
This is sort of a two part question. First, the "Flash" capability, the flash command makes the lights flash at X rate. But what is the expectation of how/when to make the lights STOP flashing? Should the driver have a set time? Does the user need to send the flash command again (or on/off manually) to make it stop?
Tied into that, is what does HSM do when you tell it to flash lights? Does it just fire the off the Flash command once and that's it? Or does it send it a second time after a few seconds to (hopefully) make the flashing stop? Or otherwise how does it intend to make the flashing stop?
The only post I could find about this was a user where their lights flashed indefinitely after setting it up in HSM, but it was a few years ago so whatever happened may be fixed by now.
This is all I could find about the capability which I think is relatively new?
I think the intent is indefinite until the user stops it somehow. Since there is no explicit command, I've done what I can find as apparent convention. We know that for the Generic Z-Wave Central Scene Dimmer, whose code was provided as an example, these commands are on(), off(), or setLevel(). For color/CT-capable devices, I assume this might also include setColor() and friends plus setColorTemperature(), though convention is not as clear there.
However, some devices have a native flash(-ish?) support an an inherent or perhaps settable but not indefinite timeout. Hue bulbs, and probably many other Zigbee bulbs, are one example (the lalert effect on Hue bulbs, which I assume might stand for "long alert" or something to distinguish it from the single-flash alert effect, which I think corresponds to the Zigbee Identify feature as you might get when tapping a bulb in the Hue app to figure out which one it is). It's something like 20 or 30 cycles, and that's it.
So, maybe it really just depends on the device. Definitely unclear, in any case, as you mention. If the device is capable, I'd say indefinite is probably the expectation generally, though.
(Also, the capability that standardized this command is relatively new, but the command has been around a while as a common custom command for some time. I didn't realize that parameter became required, though!)
Yeah I was going to make it stop if any other sort of on/off type commands are done. Also if you send the flash command again while its going I have it stopping, but maybe that is not good. I think I am going to add a safety timeout as well to prevent it going for forever unintentionally. Maybe 30 seconds or maybe calculate 20 cycles based on the rate being used.
Really need to know what HSM does I guess. Also HSM standard rules only allow you to pick a device with "Flash" but custom rules allow you to pick any switch. So I don't even know if both of those do the same thing or not...? Was hoping I did not have to create and then trigger HSM alerts just to figure out how it works.
I have a special request to have it work with HSM, so don't want it to get all setup and then the lights flash forever and don't stop!
Had to do testing to answer my own question. For both the built in and custom alerts it appears that HSM just fires off the Flash command when the alert goes off. The only way it stops is if you "Cancel Alerts" in HSM. When you cancel the alerts it just sends an "on" command to the device. So apparently turning the device on is the expected way to make it stop.
I guess I will take the feature to press the button a second time to cancel out, just leave it with on on/off, and also a built in 30 cycle timer (or 4 minutes whatever is higher) as a backup so it does not just run forever and kill your zwave mesh.
does anyone know the order it sends if you have a set color and a flash for the same bulb..
reason i ask is i want to set for instance blue for water leak but orange for fire etc. and then flash.
the problem is if you flash first then set the color the bulb just goes solid on withe the color..
at least for the ones i have tested.. if you do the color first then flash all is good.
thanks.
i would also like to trap or get an alert on the flash command via a triger so i could write a rule to keep the hue lights flashing till the alert is cleared.. i dont see that other than may modifying the coco hue driver myself..
for anyone looking for this.. here is my rule to support this.. the under bar does not need to be refreshed every so often as it goes forever till turned off.
it was kinda a royal pain in the â– â– â– as i had to redo my entire hue system to cocohue from stock hue as stock does not support the flash command. And there is no swap device support for hue devices..
what is not apparent in the above rule is the flash command is reached in rule machine by usimg the run custom action option, using an actuator for the devices.
Normally any command intended to set the state of the bulb will stop flashing. This includes on or off but also commands loke Set Color. So, you'd definitely need to set that first.
The "Advanced..." driver looks like it just uses the Zigbee "identify" command internally. Different bulbs may implement this slightly differently, so if yours only does white, that is probably by manufacturer choice and not something you can change (unless you want to use a workaround like repeated on/off commands instead, which is how some drivers do implement this command, or it can be done at the app level, not that either is a great idea).
thanks thats is backwards at least for the garden spots and many lights which if anything is set ie on/color as noted after flash the flash stops.. so guess i will just go with my rule above instead of the built in flash.
