This is a suggestion for a possible HSM enhancement.
One of my main uses for HSM is leak detection. When a leak is detected, I have HSM shut a main water valve and set some lights to Red to indicate the problem. All pretty standard stuff.
What I'd like is a enhancement where, if water is triggered, before turning on lights, setting dim levels, changing colors, etc., HSM first captures the state of all of the light devices selected for the HSM alert. Then, later, when the alarms are cleared, that state gets restored. On the UI, this might be as simple as a toggle "Restore light state after alert clears" or something like this. Functionally, this would be kind of like the "Capture/Restore" ability in Rule Machine 5.1
