HSM/DASHBOARD/KEYPADS totally broken for me as of 2.0.7.124
If I try to use dash board to set a mode, dashboard THINKS it's set but apps/hsm doesn't. If I set a mode USING hsm, neither dashboard or keypads think it's set. The keypads NEVER change modes unless I go into each one and change the mode myself. Disarming via the keypad, once i've changed the mode manually, seems to work.
The whole interaction of the 3 componets seems totally broken to me. They all worked fine in 2.0.6
Anyone else having problems??
PS: I haven't noticed any other issues yet other that my Remotec ZFM-80 Switch does not update it's status if I manually press it's button.
I can confirm your exact findings. Just did 2.0.7 upgrade, all keypads stopped working. Unlike your situation, I can not disarm via keypad either now.
I found the update notes where the new device type needs to be selected for the Iris v2 and v3 keypads. I've changed my v2 keypads and they "sort" of work now. I need to do more pattern checking and I'm getting too tired for tonight. For now all I can say is they now make noise again, but seem "weird", unscientific I know. HSM status still doesn't change to ARMED when I arm the system via the keyboard.
My v2 Iris KP seemed to be automatically Arming my Hub, post update and Driver reallocation.
Looking into HSM and possible causes of the auto arming, I removed the KP from HSM and it stopped auto arming.
Rebooted Hub, then went through HSM hitting Done and it seems to have restored normal operation.
I believe my issue might have been fixed in 2.0.7.215
I can't extensively test because of travel but at quick glance is working much better.
Iris V2 keypad working fine here on 2.0.7.125
I think I’ll hold off updating until tomorrow (Saturday)
