Yes. It's usually only 4, which further made me suspect my keypads. (I have 4 keypads) but as I'm looking through the event logs there are times where it's 4, times where it's 2, and times where it's 6, so it's not even consistent.
Sure thing:
FYI: In this particular instance I "armed" HSM via the dashboard, not via any of the keypads, but I have the same problem regardless of how I arm HSM.
On the atomicState side of things, I think I just made a breakthrough: I just did another test of atomicState which is very interesting:
If I use this log.info line, it works:
log.info("atomicState.triggerTime is currently set to: '" + atomicState.triggerTime + "'")
result:
[app:581](http://192.168.0.55/logs#app581)2019-02-11 06:50:03.864 pm [info](http://192.168.0.55/installedapp/configure/581)atomicState.triggerTime is currently set to: '1549932504445'
So it looks like atomicState doesn't like being accessed multiple times in the same line of Groovy code?
If I add both log.info lines back in, IE:
log.info("triggerTime= '" + atomicState.triggerTime + "', now() = '" + now() + "', now() - triggerTime = '" + now() - atomicState.triggerTime + "'")
I get:
[app:581](http://192.168.0.55/logs#app581)2019-02-11 06:56:14.796 pm [info](http://192.168.0.55/installedapp/configure/581)triggerTime= '', now() = '1549932974794', now() - triggerTime = '1549932974794'
[app:581](http://192.168.0.55/logs#app581)2019-02-11 06:56:14.793 pm [info](http://192.168.0.55/installedapp/configure/581)atomicState.triggerTime is currently set to: '1549932603877'
So the line that only accesses atomicState once seems to work, the line that accesses it twice returns a blank value.
I tried modifying my IF statement to only access once, but it still doesn't seem to work there. Definitely something funny going on with atomicState though.
