HSM armed and disabled?
Hi, I use HSM for a single water sensor. In the apps list it reports armed for water, but when I click on messages it also says disarmed. It just went off on an apparent false alarm, the water sensor reported wet and then 1 second later dry, there was no water present, so I believe "armed for water is correct". See screenshot
Screenshot_20210406-194736|230x500
Disarm is for intrusion alerts.
Disarm All would be for both Intrusion and Water/Smoke (if you specify a compatible smoke and/or CO detector).
Thanks for the explanation!
