HSM app shows armed but Dashboard doesn't and won't change
Hi, I'm a new Hubitat user, C5 hub running System startup with build: 2.1.4.130
I have a smoke detector and I loaded the HSM app and set it up and it shows armed. However the dashboard HSM status shows All Disarmed. When I click on the HSM Status in the dashboard and press the Arm All button, I see the event in the System Events, but the Dashboard still shows disarmed. HELP!!
Screen shots (remove the square brackets - cant include links)
drive.google[.com]/drive/folders/1y692fiNLsyBhA9ztXNpfqvs6Gpe2mnhJ?usp=sharing
The dashboard status is intended for intrusion, not for other custom rules as it is the normal use-case that once armed, the smoke/co monitoring would be left armed all the time and would not have to be armed and disarmed. The tile on the dashboard is intended for control over the Intrusion options in HSM.
Thanks!
