@djgutheinz
I’m trying your current Tapo Integration because TP-Link recently confirmed to me that newer HS210 firmware disables the legacy local LAN control on port 9999.
I enabled Third-Party Compatibility, installed your current package, added both of my LAN segments, entered credentials, and ran discovery.
The integration successfully discovers my Kasa devices, including the HS210, but reports:
HS210(US): DevType IOT.SMARTPLUGSWITCH not supported
It also reports the same device type as unsupported for HS103, KP303, EP10, HS200 and HS220.
TP-Link support told me the newer HS210 firmware intentionally removes/disables port 9999 for security, which breaks the older Hubitat Kasa local integration.
Is there a way to support these firmware-updated legacy Kasa devices through your newer local protocol implementation? I can test an HS210 if that would help.
I can also provide the discovery screenshot, firmware version, hardware version and debug logs if useful.
Tapo released some updates in late August. This may be the next wave of transition from XOR (port 9999) to KLAP (secure). For the Kasa devices, I suggest disabling automatic firmware updates until this is resolved. (sort of a "if it isn't broken, don't fix it>).
Information request: Firmware Version?
Note: All the devices I have seen recently (until now?) have had dual port capability. I have a KP-303, HS300, and some others that work fine using the built-in KASA App. However, things change as TP-Link evolves it architecture.
Recommended:
- I would try removing and reinstalling the device in the KASA or TAPO phone app (will not impact Hubitat install). Then try again. But, TP-Link
- Try removing and reinstalling the device in the TAPO / KASA phone app (takes no other changes). Th devices to-date have been dual-protocol, supporting both XOR (port 9999) and KLAP (TP-Link) protocols. Then try in the existing TAPO app.
Good news: I am updating the code for the Built-In Kasa app right now. I am near the end since it is quite involved since I am merging three protocols (XOR, KLAP, and AES) and two API's (IOT (kasa) and SMART (tapo) into a single integration.
Current Status: Have the new integration running and tested without errors as a fresh installation. I am 90% complete on the transition code (bring in already installed Kasa Devices). Will then provide to Hubitat for their decision on inclusion (if not, I will publish as community). Anticipate my work completed by mid-October - but ....
What the new Supports: PLUGS, SWITCHES, BULBS, and LIGHT STRIPS from either TAPO or KASA. It will not support TAPO/KASA hubs, cameras, vacuums (security protocol issues). It will also automatically update devices (attempt to) if the protocol changes in the future.
Regards, Dave
