How to wire zooZ Zen16 to garage door opener
I don't really need the original button. Just Thought it would work too.
Let me make sure I understand the wiring. According to the installation instructions that came with this new button, Normally, I would use just the white and red/white wires from the back of the button to the garage door opener. It didn't mention using the additional wires on the side of the new button. So in order to use the Zen16 I thought I would just connect the white and the red/white wires from the new button to the Zen green Switch 1 and then run wires from green Zen R1 and R2 connections to the garage door opener. as illustrated below.
Are you saying in addition to the wiring I described I need simply twist the new button's side wires together? Or does the white and red/ white wires connect to the garage door opener AND the new button's side wires go to the Zen16 instead or the white and red/white wires?
