How to Trigger a RM after Restart or Start HE?
I'm facing a problem here....
I am getting blackouts quite often and every time my HE start in the same Mode.
I have a Rule who select the proper Mode according the time of the day so I just need to trigger that rule in order to get the correct Mode... but I couldn't find a way to achieve that exactly AFTER RESTART.
Any Idea?
**please don't tell me to install UPS I know..... (I have it but without batteries :woozy_face: because in our cuban stores we haven't almost nothing.. but that's another story ... and I cannot buy online either. So please focus on my question not go around :stuck_out_tongue_winking_eye:)
Check this thread, I think this is what you are looking for, I have not tried it so...
And, yes, it works. I see the refresh done on reboot/restart.
"systemStart" as a trigger works great. I use it on my hubs to force a time refresh and Pushover a "rebooted" message to my phone.
Thanks a Lot!!!
This option is more hiden than gold in a mountain :grin: LOL.....
Thank you for confirming that.....
Do any know if there is any command, action .. I don't know how to call it but something I can trigger to renew my Hub IP?
that will be great.
The hub should continue to keep the address that was given to it if it is a DHCP Reservation. You don't want it changing, as other stuff will quit working.
What is the usage case where you need this option?
My problem is that my DHCP is in a VM who start minutes later than HE so it never got the correct IP after a blackout. When that happened I had to use a button to restart the HE or remove the power plug (I know is nor correct but no other choice here).
If I can renew my IP after restart then my problem is solved.... I'm using a C4 version so no way to use static IP.
Any better idea ?
