How to pause rule for a specific amount of time
Hello. I am sure many of you experience at times that even though your rules they need to be paused occasionally. Generally it has to do with lights going off when someone is in the shower and no motion is detected. I may end up going with a moisture sensor but until then I set up a remote button to pause the motion sensor rule when someone is taking a bath. It works fine but instead of it staying paused until it's resumed, is there a way to have it resume after a specific amount of time? TIA
Use "Wait"
Didn't see that option. Should have looked a little closer. Thanks!!
Wait is your friend, but if a rule is triggered again, the existing wait is canceled. Just good to keep in mind if you have rules that can be triggered multiple times.
My programs that use wait normally have a cancel in front to prevent conflicts ie: door opens again while waiting for previous close to trigger locking
