How to migrate to C8 Pro
Trying to migrate from C8 to C8 Pro.
Recent cloud backup cannot be selected.
Anyway to make this more than a paperweight?
Have you updated the C8 Pro to its most latest firmware? The initial firmware could not see cloud backups.
I encountered the same issue. Instead of using the migration links through the process, I registered the C-8 Pro as a new hub. Then I navigated to the Backup & Restore page, where I could see the latest backup of the old hub. Even though that latest back up was not deemed "migration worthy", it worked just fine. Side note, in case it matters: I had a hub subscription on the old hub, which I then transferred after the migration completed successfully.
Please check out the following document. Migration from C-8 (or C-5/C-7) to C-8 Pro is the same as migrating from a C-5/C-7 to a C-8...
