I just experienced a power loss to my HE hub (and the whole house). This happens so seldom I really have not been concerned.
I've read about others experiencing database corruption due to a power loss. And I know there are some fail safe features to minimize corruption.
Question: How would I recognize if my hub was corrupted due to power loss. Is there a definite indicator or will some random rule be corrupted and just not work?
Iβve found that Itβs generally all or nothing.
If the database is corrupt and not able to correct itself or restore a backup successfully, you will find the hub will not boot past about 10%
For what it's worth, guys... It's probably a good habit to get into to occasionally pull a backup of the DB down. You can ask the hub to give you a copy from the 'Backup & Restore' menu item in the 'Settings' menu. The hub holds some periodic backups of it's own, but there are definately scenarios where you'd want a local copy (the most obvious one being in the event of an entire hub hardware failure).
I don't know you about guys... but it would take me a good while to re-build the whole setup if the hub died... so take the odd backup
Is it possible to create an image of the Hubitat USB stick to create a backup? I'm guessing there might be some encryption conflicts - or maybe not. I wouldn't expect ever having to use it, but it might be nice to have around.
Yes, but only for the z wave (tested and confirmed), I will test something with my development hub with the zigbee, but probably will fail, the PAN ID must match the network and I don't know if it is stored in the chip/stick or in the hub DB.
