How to insert a variable in a "he wattr" payload?
In the below command I would like to replace the 076162636461610d with the variable serialdata.
I've tried ${serialdata} and $[serialdata] neither work.
I also tried, without success:
    def serialdata = {104 3 02 0E00 42 076162636461610d }
    "he raw ${device.deviceNetworkId} 0x01 0x01 0x0014 ${serialdata}"
any suggestions?
thanks
John
Working code:
def WriteAttr_() {
    def serialdata = 076162636461610d
    "he raw ${device.deviceNetworkId} 0x01 0x01 0x0014 {104 3 02 0E00 42 076162636461610d }"    // Works !!
Seems like you want this to be a String, in which case the value would need to be enclosed in quotes:
def serialdata = "{104 3 02 0E00 42 076162636461610d }"
As is, you've instead create a closure (with the curly braces) that ... does IDK what but definitely not what you intend. :smiley:
Same thing here:
Otherwise, you've done the same (in this case, probably defined in a variable serialdata interpreted as Double due to the d at the end and with octal representation given the 0 at the beginning -- and happening to have only valid octal digits in between -- tricks you can use to force different interpretation of literal values in Groovy).
Otherwise, your string interpolation looks correct!
