I used to do z-wave repair multiple times in the past. After upgrading Hubitat, somehow I can no longer find the entry to z-wave repair in the hub UI, not in any tab / any drop down menu. Did I miss anything? 2.2.8.156 on C-5
It moved. Now at Settings, Z-Wave Details.
It’s always been under Settings Z-Wave Details. But this setting is now hidden and you need to toggle “Show advanced settings” at the top to expose Z-wave Details along with other setting options.
@zhouguiheng What they said. Though you shouldn't have to do z-wave repairs all the time (it's recommended if you do hit repair on the individual node) If you're doing constant z-wave repairs you have more problems
Thanks a lot! This is the key. I somehow ignored that first option and paid attention on the second option which wasn't rendered correctly on small screen (phone)
Agreed. There's no repair on individual node however, each node under z-wave details shows the link to a device, but no other actionable button / link. Is it only available on C7?
Correct. The C-5 and C-7 have totally different zwave radios and zwave stacks.
My bad, I didn't notice the c5 comment in the original post
