How to implement tank level alarm switch
I modified a Ring Contact sensor to use it as a method to give an alarm of a high effluent tank level by soldering leads across the reed switch. It will be wired to a alarm box that has dry contacts to indicate a High level condition in the tank. My question is I added it to my Zwave mesh and it works great but when I show it on the dashboard the only way is using the "Window Template" tile. Is there a way of modifying the template to change the color when the contact is closed to Red and open in green. Also change the icon from a window to something else. Also I wish to use this device to trigger an Aeotec Siren 6 device and how to use rule machine or something else to do this. I am a newbe so please be kind....thanks...
You can change the colour and icons in the template section of the dashboard settings.
Thanks.....just changed the tile...lovely! Now have to figure out how to trigger the Aeotec Siren 6
