Hi
I suspect the HE Hub is running slow because of loading despite a hard reboot.
Is there a way to determine what the Hub loading is like?
I am still investigating the below...
Trying to get a rule working where it Turns off the central heating boiler when not needed.
The logs show the Rule running and sending the commands
app:6132021-11-14 18:20:00.875 infoAction: off() on Heating Boiler
app:6132021-11-14 18:20:00.858 infoAction: off1() on Heating Boiler
app:6132021-11-14 18:20:00.780 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
app:6132021-11-14 18:15:00.501 infoAction: off() on Heating Boiler
app:6132021-11-14 18:15:00.485 infoAction: off1() on Heating Boiler
app:6132021-11-14 18:15:00.372 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
app:6132021-11-14 18:10:00.995 infoAction: off() on Heating Boiler
app:6132021-11-14 18:10:00.982 infoAction: off1() on Heating Boiler
app:6132021-11-14 18:10:00.953 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
app:6132021-11-14 18:05:00.452 infoAction: off() on Heating Boiler
app:6132021-11-14 18:05:00.438 infoAction: off1() on Heating Boiler
app:6132021-11-14 18:05:00.392 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
app:6132021-11-14 18:00:01.443 infoAction: off() on Heating Boiler
app:6132021-11-14 18:00:01.429 infoAction: off1() on Heating Boiler
app:6132021-11-14 18:00:01.399 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
app:6132021-11-14 17:55:21.343 infoAction: off() on Heating Boiler
app:6132021-11-14 17:55:21.326 infoAction: off1() on Heating Boiler
app:6132021-11-14 17:55:21.304 infoBOILER ***** TURN OFF BOILER Radiators: Actions run by BOILER ***** If Heat Demand Turn ON or OFF NEW
However the Boiler Device is NOT recording that it received the instruction to shut down.
How do I get the Rule to actually send the OFF control
It has been working for the last year but is now playing up.
Can anyone advise on debugging why it takes sending a zwave Off command 7 over 35 mins before it actually does it.
