How to disallow access to my api
I've given a website access to my api. Now after evaluation, I want to remove that permissions. How does one do that here?
I take it this is via Maker? If so, the options below will help.
You could take away the access from the Cloud, or if thats needed for other things, create a new token, and update your IFTTT for example. That will stop the other site.
Thank, how do I get to that screen?
Open Maker API in the Apps list. Do you have Maker API installed?
If not, which service have you given access?
How did you set this up?
Thank you Royski, your question led to the solution. I've removed access. Thanks
