Google replaces the actual "intelligent" IFTTT integration (which allows variable input text and number) with a "dumb" integration (which allows only to activate a certain scene).
More:
IMHO (when I understand the reddit talks) the variable input API is deprecated - so all other solutions will also break.
You might want to look into the Echo Speaks app for Hubitat.
It’s for Amazon Echo devices, not surprisingly. But it’s extremely flexible and customizable in terms of how it can allow one to integrate Alexa-enabled devices into a Hubitat environment.
There’s also an integration for Mycroft, which has the advantage of running entirely locally. I believe the development of the integration is in beta, and I’m uncertain how fully featured it is as a voice assistant given that it doesn’t use any cloud processing (I haven’t tried it out myself).
You could get creative with the use of virtual switches and either RM or WebCore to process and speak the defined data.
Example:
You say "OK Google, Bathroom State"
Google recognizes Bathroom State as a custom routine to turn on virtual switch bathroom state.
Rule/Piston is triggered by virtual switch creating a string pulling in data. Bathroom light is on and temp is 70 degrees.
Speak data string
The tricky part would know which google device to route the speak to (assuming you have multiple devices in different rooms).
I've just built a Rhasspy unit (local voice recognition) and it requires that the phrases that you want to use as triggers (eg 'turn on [room] light) need to be defined in a configuration file. I assume Mycroft would be similar, without the processing power of google/s/Amaxon's cloud servers.
I don't use Google Assistant but I was curious so I did some searching. The main issue OP has is capturing the "variable" voice commands, I don't think Echo Speaks can do this. I see lots of people saying they are switching to Alexa but I don't think you can do this there either (If you can I would be interested as it sounds possibly useful). The variable commands without a unique routine and switch for each one is the key.
That's the problem: I would need a new virtual switch for any possible combination of parameter.
E.g.: set temp in x to y
When x is one of 15 locations, and y is an integer between 15 and 24, there are 15 x 10 possibilities => 150 virtual switches just for this simple use case!
It is quite easy to put together with a pi3 or better and a microphone shield (reSpeaker) or even using a usb combined speaker/microphone so no wiring needed at all. Quite a few guides on the internet that will walk you through the process. I tried it with a pi zero but it's pretty underpowered.
I no longer use Alexa (as much) but @bamarayne21 or @tonesto7 might be able to help point you in the right direction. Although, you could probably continue to use IFTTT with Alexa the way your applets were running using Google Assistant. Just remember, that with any cloud services, you are at their mercy of changing course at any time and you cannot do anything about it.
Found this thing that claims it can take input from Alexa and send webhooks out, but it is a bit pricy. Sounds similar to what you were doing with IFTTT but you would need to setup a key word phrase for each command in Zapier from what it sounds like. Plans & Pricing | Zapier
Along those same lines... searching a little, a custom Alexa 'skill' might also do the trick. Something where you could setup a key word and then everything after that you send to a webhook. I believe thats what you were doing with Google? I have looked into making a custom skill before (to display a web site on a show in a certain way the built in browser was refusing to do) but it got overwhelming pretty quickly and I gave up
For those of us who want to stay totally local, the Mycroft will supposedly be available this fall for $300. But it may be the ugliest device on the market...1985 will soon be calling wanting their tech back...
