I'm not able to clone Dashboard by using "Clone" option in Dashboard Settings. I know that Copy /Paste .jason is an option, however that would require to re-select devices all over again. Could someone show me the steps to use the "Clone Button"?
That should really do it, besides following the prompts to replace one device with another if you want (same for any cloned or imported app). It should create an identical child app under Apps > Hubitat Dashboard. If that's not happening for you, maybe there is some other issue going on.
Thank you for the response. My intension was to use the โClone Optionโ in the dashboard settings. However it takes me to a blank page with no options to choose from, therefore no clone created. It used to work in some of the older versions but not after the last few updates.
