Just swapped out my old router to a mesh system - Nighthawk MR70 w/ 2 satellites and everything went great, was able to not have to fix really anything except silly Konnected integration w/ Hubitat. I swapped routers, kept the network name & password the same and everything swapped over.
The Konnected boards connected to the wifi no problem, however the IP address associated with them is not correct in Hubitat. See picture below. This is from the router.
you should have had your old ip address as a dhcp reservation in your router.. then this would not have happened.. you can add them in.. reboot the reouter and reboot your boards and it should go back to the old ips an dthen all should work
I don’t know what Konnected device you have. I don’t have my Konnected alarm hooked up at the new place yet but I have two of the Konnected gdo BlaQ hooked up. On your Hubitat in the device page on the preferences tab, you can update the IP address.
Backed up the Hubitat, screen shoted the Konnected boards pinouts, then just started breaking stuff…
Started with unplugging them and plugging them back in, that didnt work. The went to Konnected’s website and was going to factory reset the Konnected boards so I could just redo everything. After holding the reset button for 10 seconds two of the boards magically fixed themselves in Hubitat. The third board would not though, so I had to delete that one board and re add it into hubitat.
Was pleasantly surprised I didn’t have to do the boards with all the inputs, just the board with the house siren.
