I’ve done this before but completely forget how to do it. I need to receive laundry status messages from Hubitat to my new devices. Already deleted the old ones from Hubitat but can’t figure out how to add the new. Thanks in advance!
See here:
Already have the app and have experience with it! Can you point me to where I can use it to add my iPhone and iPad as devices?
Follow the instructions @marktheknife posted above
- Launch the mobile app on your smartphone or tablet. When asked to log in, use the same Hubitat account that you used to register the hub previously or in step 1.
- If asked to select a hub, select the desired hub (if you have multiple hubs, note that the app can be associated with only one at a time, but it can be switched between hubs).
- If asked to choose a mobile app device or create a new mobile app device, select the appropriate option:
- Choose an existing mobile app device from the list if you have previously used your current mobile device with the selected hub (or wish to associate the existing mobile app device on the hub with this one, e.g., if you upgraded/replaced your phone)
- Select "Create new mobile app device" if this you wish to create another mobile app device on the hub for this mobile device (e.g., if you have an existing mobile app device for your phone but are creating a new one for a family member on another phone, a tablet or additional device for yourself, etc.).
If you don't get the option to create a device you will probably need to logout and log back in
Yes as @CaptWoody said, the instructions to add your mobile device to the hub are in the linked documentation article, in the “how to use the mobile app” section of the article (the same as he pasted into his response above).
