For me, the ring contact sensors are the most reliable contact sensor that I've found and they do not suffer from the drop out I've seen other sensors suffer from and disappear from the mesh. However, it was tricky to get them added so I spent quite a bit of time researching this and found the steps that work every time and thought I'd share. I suggest reading through the steps to end before you start the process.
Once removing the contact sensor from the package and removing the paper band holding the sensor and magnet together, set the magnet aside
Remove the contact sensor back cover by sliding it out
Remove the battery cover via the phillips screw
Perform factory reset by inserting paper clip into the reset button next to the batteries. Keep holding until the led near the front button turns red.
In Hubitat, go to Settings - Z-WAVE Details
Take out one of the batteries from the sensor
In Hubitat, click the Start Z-wave Exclusion button
Put the battery back in
Press the button on the front of the contact sensor for at least 5 seconds and release.
In about 15 seconds it should be recognized and you should get a message that an unknown device was excluded.
If not, don’t worry and continue the steps
Remove the battery again
In Hubitat, click on the Add Device button
Click the Start Z-wave Inclusion button
Insert the battery
Press the button on the front of contact sensor for at least five seconds. When you stop pressing the led should start flashing
In about 30 secs it should be recognized and you should receive a message that it was included.
Reinstall the battery cover and back cover (clears the tamper indicator)
Click Next
Go to Device Info tab if not taken there by clicking Next
Change Type (drop down) to Ring Alarm Contact Sensor G2
Change Device Name to Ring Alarm Contact Sensor G2
Verify Device Label and Room
Click Save, wait for confirmation (may need to click twice)
Go to Commands tab and verify that Tamper is clear
Put magnet on Sensor and it should show closed
You're good to go!
