How I got massive improvements on Stability, Functionality and Performance
I know the HE forums are more for dev stuff and not community discussion and are highly moderated - so posts like this one can get poor reception. But I do like sharing even if it tends to paint a target on me.
Having been with HE for a while now (8 years?) I've learned a lot and been through a lot. A LOT. In the last 12 months my stability has never been as solid as this. Even back when I first implemented a unit fresh, it seemed not trustworthy. That is a subjective opinion and no doubt will get responses by itself!
I wanted to share what exactly have I done that has brought me to a point I'm actually seeing my Hub not as a DIY project, but as an actual important device for my home.
Factors that have brought my Hub forward:
Things improved for me substantially a while back when I got a C7. Not a knock on c5 and c4, just pointed at demarcations of stability. I think that the C7 really was a leap forward moment, at least for me. I tend to have a Repeater in every room of the house. Overkill? probably - it was a marked improvement to my Zigbee network Stability.
Standardizing on Zigbee. I know this is one that a lot of people disagree with me on. Sorry. Don't care! FOR ME, trying to maintain ZWave, all its versions and range choices - versus cost and simplicity - I opted for Zigbee and I've never looked back. Has it had issues? Yep. But it's simpler for me to maintain. Subjective. yep.
Recently (a few months back) I lost a repeater and had a hell of a time. I was ready to put my HE in the trash, I swear. But I stuck it out, found the issue and that was a HUGE weekend for me. I located older devices that were on pre-3.0 Zigbee and removed them - except for my HE of course, which is still older at the moment.
Which brings me to the kudo's to others HERE, in the forum. The recent plethora (to strong a word?) of apps that are available as diagnostic tools - humongous! Being able to see the map and devices? Being able to get detailed info? yea. I wish I had these tools 5 years ago!
And now, being able to distance myself some from the pre-built stuff and do it myself. Thats where things also have just got better and better. I recognize and appreciate that HE provides basic system stuff. And it works very often - especiially when you aren't sure what is available. But being able to extend that basic stuff and build out better stuff is where things also just got better and better!
That mindset - of breaking out and create the right part for the job (eg; a driver for third reality plugs that intelligently knows if it has power monitoring or not) has brought me so far forward!
I'm now applying this same logic - diverge from using built in if possible to improve on the foundation - is really getting me to an unbelievable place! It started by getting away from the dashboard, and using (more kudo's) HD+. Then moving from builtin mode management to a highly advanced mode manager! I've just completed moving all my house environment to one app as well! And I built what I wanted for a real Room manager as well.
I just went back and checked - I have removed 28 rules in the last 30 days. And I'm the last person you should ever take advice on for rules I assure you.
In the end - I tip my hat to HE. It's been a long road for both of us. I will no longer refer to my hub as a DIY project here or in the cloud. I actually am enjoying it and have learned so much about the logic of others, as well as how I apply logic. Thank you Hubitat.
The first hub model with external antennas was the C-8.
I do stand corrected. Editing. (that was the one I gave my GF for her house)
:roll_eyes:
This forum is for both “dev stuff” and community discussion, however it is you define the difference between the two.
It’s definitely possible some posts are poorly received for various other reasons, though.
Congrats on a stable hub. That is all we really want, and everyone takes steps to get there.
Zigbee repeaters cannot be over-stated, as well as placement of them. I see one in every room as the bare minimum - the more the better.
I've had very few issues with ZWave, but I really only use it for mains powered in-wall dimmers. I have a few sleepy ZWave devices, but at least 95% of my Zwave devices are repeaters. I had one Zwave issue being caused by faulty devices a couple years ago, but it cleared up when those devices where replaced (two in-wall dimmers of the same brand that would freeze up and stop repeating).
I've also had better luck with home-spun apps compared to built-ins, so I so I don't use RM, or Room Lighting, or Mode Manager, I like how much can be put in a single custom app compared to having many rules and other apps to manage.
This is a good recommendation regardless of protocol. zwave, zigbee, thread. Learned this back in my ST days and worked as well on zwave 3/500 and zigbee 1.2 as it does on zwave 7/800, zigbee 3.0, and matter 1.x.
It’s hard to have have mesh issues power issues when hops are no more then 20ft away.
