Yes, that looks correct. Just hit the "Set Parameter" button after you've typed in those values to actually run the command. Then, switch back to your regular driver. Also, in this case, I'd recommend avoiding the typical advice and don't hit "Configure" (in the orignal/desired driver) afterwards--just in case the driver you're using overwrites your custom parameter settings when you do so.
