When I set it to "Auto" meaning of course that it switches from cool to heat on it's own. How do I decrease the gap between the ranges? For example currently I have the auto cool down set to 69 and it forces me to set the heating threshhold all the way down to 60 which is wayyyyy too cold. How can I increase that "heater on" threshold to somehing more reasonable like 66?
Most thermostats have built in minimum delta between cooling setpoint and heating setpoint to protect equipment and keep it from bouncing back and forth between heating and cooling.. For my Ecobee, it's 5 degrees. 9 degrees seems like a lot. What model is your thermostat? Have you looked in settings for your thermostat because it is likely not a Hubitat issue.
Sorry I have an ecobee linked to my hubitat to be clear. Does ecobee have a setting to change that delta?
I figured out how to change my delta... is four degrees delta ok for an ecobee? Ideally I want the house to be heated when it drops below 67 and to be cooled when it goes above 71.... but only when I'm home. WHen I'm gone I'd like my old comfort settigns to somehow apply.
