How do i see the switched inputs from my zooz multirelay
Are you looking for open/close reports to the hub or are on/off ok? You could leave the outputs (relay terminals) empty and just use their status changes in HE to monitor the inputs. But remember that the input needs to be dry contact (no voltage) or used with a ZAC98 accessory relay if you need to monitor a low-voltage input.
