should be a cancel alert button on the page
Your screenshot doesn’t show an intrusion alert.
It says “intrusion disarmed,” which I assume is the current status of your HSM intrusion monitoring?
I just set off the alarm again, and yes, the cancel button appeared. But it did not reset anything.
I thought before that it showed "Disarmed"
Can’t help you there, but if the current status of HSM is that intrusion monitoring is disarmed, and water/leak alert monitoring is armed, then your screenshot shows what I would expect.
Here’s what mine currently looks like. Intrusion alerts are disarmed, smoke and water alerts are armed.
I guess that is the way it is supposed to be. For some reason I thought that it used to show a green "Disarmed" but maybe not. Thanks.
