How can I make these devices added via smartstart move beyond pending?
I'm on a C8 Pro, latest firmware. Using zwave JS. Moved somewhat recently and have been trying to add devices using SmartStart when available. I installed two Zooz Zen77s. I wasn't sure if they had been excluded from my network before removed from my old house, so I turned the breaker on and factory reset both switches. Then I turned the breaker back off. Rebooted my hub. Then used the app to add both devices via SmartStart. I turned the breaker back on, but neither device has moved out of a pending state.
I've tried powering the switches off and on again via the breaker. I rebooted my hub again. Not really sure what else to try to be honest. What's weird is that the hub seems to be able to see the devices. They show up in zwave details.
It just doesn't seem to want to prompt me to add them as devices.
EDIT: Just to see what would happen, I cut the power to the switches, deleted the smart start entries, rebooted the hub, scanned the QR code to add them back via smart start, restored power to the switches, and the same thing happened.
I'm pretty sure this is what kept happening when I first tried SmartStart years ago. I thought maybe the process had improved since then...
That looks like your Z-Wave Details table, not a list of pending SmartStart devices (i.e., ones added to the SmartStart list that have yet to complete inclusion). I'd use "Remove" to get them out of that list and clean up failed inclusions, which may cause problems, then try your whole process again -- although you can leave them in SmartStart since that's not going to change (assuming they are still there) -- including a factory reset or general exclusion of the device.
In other words, what you're seeing in that table is two failed inclusions -- not two Z-Wave SmartStart devices waiting for their turn. That should help direct your troubleshooting, at least!
