cool didnt know that..
im probably just going to use the 1500 i have currently at our cottage that i have my qnap on as i will also put the cable modem and router on the same ups. I have a 9631 net card from amazon used coming today to put in.
also be aware the smc models have less run capacity than the smt even at the same rating
ie smc1500 != smt1500
ie
compare APC Smart-UPS Runtime Chart | APCGuard.com
and APC Smart-UPS Entry Level Runtime Chart | APCGuard.com
for your smc1000
3 hrs vs 1 hr
SMT models definitely out perform the SMC versions.
https://www.apc.com/shop/us/en/tools/compare-products/y2k41/SMT1500C|SMC1500C
FWIW I now have this working with my dumb UPS and my Windows 10 laptop. only issue is I am still unable to send notifications such as onbattery, offbattery, but get an update every 10 (user adjustable) minutes.
You must have a method to run a PHP script. I've run a WAMP server for years for my website development and testing, so that helped. Should you get beyond that hurdle, the remainder or the info is at the following:
Updating this thread with my solution
Modified the APC UPS Monitor Driver to work with some VBS scripts I wrote that interface with the apcupsd app.
Shutdown is event driven when the apcupsd app issues a "doshutdown" event. Big plus no PHP server required, and little or no modification to apcupsd scripts.
